MKE is fairly spotter-friendly, with the spotting area at the north end of 19R. As you discovered, the parking garage is also acceptable, just be prepared to get checked out...not normally a big deal. I've been up there for a few hours though and they left me alone. I guess it all depends on their mood.
The spotting area is good for afternoon and evening shots when they are using 19R, but sometimes they will run a combo pattern with departures on 19R and arrivals on 25L. In this case the arrivals are too far off for even a 400mm...for departures on 19R you will need some way to "get over" the two fences that are in your way. I use the back bed of my truck with a three-step stool, it works nicely.
Supposedly they are going to be putting in a new spotting area near the end of 7R, but so far haven't seen it happen.
-George Widener
http://www.flickr.com/photos/md11forever/
Reason: bad photo links
- You may not post replies
- You may not edit your posts
Forum Rules
