Thread: Canon Camera Settings?
    Mar 2006
    I'm curious. What settings do the Canon camera users here use?
    ISO, aV,Tv or Manual, etc.
    Plus, JPG or Raw
    and lastly
    The custom settings (Sharpness, Contrast, etc.)
    Paul
    Expanding Beyond PHL
    http://phlairline.com
    Re: Canon Camera Settings?
    I use Av for the planes and M for everything else.
    nwafan20 turned me to RAW and i love it.
    I don't use any custom settings, everything I can do in post-processing.
    "lol retart"
    May 2006
    Aperture priority (Av) at f/8 for jets, adjusting ISO for shutter speeds > 1/500s. Shutter priority (Tv) at 1/125 or lower for props to get prop blur. Everything is shot in RAW, with contrast, sharpness, etc. all tweaked in post.
    My settings are pretty much the same as Phil's, although I use M when it's partly cloudy and the light isn't consistent. I shoot at the lowest ISO that lets me keep the shutter speed high enough...usually ISO 100 in good light, but even at ISO 800 you don't get a lot of noise if you overexpose a bit...
    My standard shooting mode for sunny conditions are the following
    ISO 100
    TV Mode- 400 to 800th of a second which will acheive an F stop of between 9 and 10 which is the sweet spot for my camera and lens.
    Exposure compensation dropped by 1/3
    Cloudy conditions.
    ISO 200
    TV Mode- 400th of a second
    Exposure compensation increased by 1/3
    Josh May got me into TV mode and I haven't gone back, I swear by it. My shots are infinitely better when I use TV mode over AV mode. I think you have more flexibility.
    Walk around shoot (non aviation)
    Manual mode
    I shoot in JPEG mode, if you take the shot right the first time there is no need for RAW as it takes up needless space on a memory card and the PC. I believe if you know how to use your camera and manipulate the light correctly the first time your post processing will be kept to a minimum. RAW is a crutch IMO but some ppl swear by it.
    Sunny days:
    M anual mode
    ISO 100
    f/8 or f/9 depending on how much light.
    Shutter 1/500th
    Cloudy days:
    AV Mode
    ISO 100
    f/8 or f/7.1 if the clouds get more prevalent.
    Keep the shutter as close to 1/400th as possible.
    Non-Aviation
    Full Manual, set the camera for the situation so I am 1/3 stop over neutral.
    Jul 2006
    Albany, NY
    I normally use Av with ISO 100 for aviation. Aperature set to F/8 or F/7.1 if the light will allow. I'll move it down to 5.6 if the light conditions require it.
    When I was using the Digital Rebel (300D) I used to go to manual mode for predominantly white aircraft (F/8, 1/500 would normally be a good starting point on a sunny day). The Dreb's metering was poor and would overexpose white aircraft.
    Now that I have the Xti, I put the metering in center weighted - seems to have solved the problem.
    Jul 2008
    Romford, Essex - UK
    Quote Originally Posted by runway27r
    Plus, JPG or Raw
    and lastly
    Paul
    Depends on which Canon SLR (film or digital).
    I still have a Canon EOS 3 film SLR, still feel i got a good camera.
    5 years ago for taking Concorde photos i used the following settings with a 80-400mm zoom + x1.5 converter
    Take off
    ASA 400 film, tv at 600 - 800sec (depending on weather and light)
    metering = Evaluation, Motor winder = 6 PFS.
    Landing
    On the ground
    ASA 100-200 film, full auto mode, metering = Evaluation, Motor winder = 1-3 PFS.
    Eye focus = switched off
    (While waiting for Concorde) For subsonic planes
    Take off
    Landing
    On the ground
    Custome settings for all aircraft
    Make sure all 45 AF points are used by the camera automatically
    Make sure the camera re-winds film so the front cranked part still sticks out.
    Make sure spot metering is linked to the AF point youre looking at.
    Scanning them in to PC
    For archiving and very high quality work use 35mm negatives and scan them in TIFF format at your scanners highest setting.
    For just sending to friends (via e-mail), posting on the internet use a photo and scan in at JPG at around 300 dpi.
    Use Adobe Photoshop or Coral paintshop Pro to clean up images and correct the colours.
