Results 1 to 15 of 20
Thread: Southwest's Business Strategy Post AirTran Acquisition
    Dec 2006
    Oceanside, NY
    A thread on airliners.net got me thinking about what Southwest's business strategies may have to change after the consolidation.
    The big one, the amount of flights per new station. Southwest in general has been veering off of their usual business strategy over the last few years with new flights to LGA, BOS, MSP, and MKE. A typical requirement for Southwest starting service to a new city is USUALLY that the station would be able to support 12-15 (somewhere in that range) flights from the start. Will a consolidated Southwest/AirTran be able to maintain that strategy?
    Also, the BIG issue Southwest takes to heart. According to them, they have no hub cities. Will they change their mind after seeing how many of their flights operate into and out of Atlanta and finally declare a "Hub"? Let the debate begin...
    In loving memory of Casey Edward Falconer
    May 16, 1992-May 9, 2012
    Southwest does have BWI, MDW, PHX, and DFW as their hubs
    Senior Member steve1840's Avatar
    Dec 2010
    Nashville, TN
    Quote Originally Posted by Delta777LR View Post
    Is KLAS a Southwest hub also? And doesn't Southwest use KDAL instead of KDFW?
    Steve Furst
    View my work @
    Furst Edition Photography
    JetPhotos.net
    Yea I believe you are right, KDAL..
    Dec 2006
    Oceanside, NY
    Yes, it is DAL. What I meant was Southwest does not call them hubs. They never ever use the word hub for any of their cities with a large portion of Southwest flights such as BWI, MDW, DAL, etc. The question is, will they start using the word Hub after they acquire AirTran?
    Dec 2010
    Nashville, TN
    If they don't usethe word "hub" to describe their larger volume airports now or in teh past, I don't see why acquiring another airline would all of a sudden start using it. It shouldn't really change their business model since they acquired AirTran. They currently have between 100-150 flights a day in and out of BWI and if they do not usethe word hub to describe that, I don't see them usign the word hub to describe ATL which would appear to have just as many flights.
    Steve Furst
    View my work @
    JetPhotos.net
    Tommy summed it basically. As for the hub stuff WN is not a hub and spoke carrier but they enjoy the best of worlds by using places like LAS, LAX, BWI as locations to connect flights to other parts of the country.
    Aug 2005
    Southern Illinois
    Most everyone is correct but I'll offer the terminology WN uses...
    Stations with 100 flights or more a day are defined as "mega stations"
    True, WN does not use the term hubs, they simply retime the flights to allow ICO (Internal Connection Opportunities). (Call it a hub if you want, just using WN's terminology)
    SWA has crew bases at OAK, LAS, PHX, DAL, HOU, MCO, MDW and BWI. ATL wil be the next crew base for SWA, if they do not fence it, this is still being discussed. MCO crew base for FL will become WN's, no problem there, MKE base is still being discussed, either co-base it with MDW or make MKE folks go to MDW.
    It used to be a minimum of 8-10 flights a day yes, HOWEVER in the old days of SWA, stations were only starting with 4 flights a day, so this is not entirely new. WN will keep and open what they can if it makes money, 1 flight a day or 200 flights a day be damned.
    ICO's (Hubs to you guys) are at DEN, PHX, LAS, STL, BWI, MDW and HOU. OAK and MCO are not Hubs/ICO's, there are connections made available yes, but equally at other smaller stations. WN defines their ICO's as the stations I just mentioned.
    WN will not be using the reservation system from FL or WN, it has come down to two reservation systems, SABRE and Amadeus, I believe are the two it's narrowed down to.
    WN defintly bought FL for ATL, among the capaiblities to go international as well.
    Expect a decision to be made by June now, it had to be pushed back to the 2nd quarter. They are meeting I think March 30th now.
    To answer the OP, No, WN will not be using the word HUB anytime soon.
    Alex
    www.southwest.com Bags Fly Free. Anytime, Anywhere on Southwest Airlines. Share the LUV!
    Dec 2010
    Nashville, TN
    Just out of curiosity, and not to change to direction of this thread, but what is going to become of their fleet of aircraft? I know that Southwest wants to have a stable of all one type of aircraft. Are they going to sell off the non 737 aircraft in the AirTran fleet, or are we going to be seeing whale-tails in Southwest colors?
    Steve Furst
    View my work @
    JetPhotos.net
    Senior Member TSGSpotting's Avatar
    Oct 2010
    Central Connecticut
    Southwest plans to use the 717s I think.
    Trevor Guglielmino
    My Photos
    Canon T2i/60D
    Senior Member sporky's Avatar
    Mar 2009
    DFW Area
    I believe WN will be keeping the 717's and going to a 2 plane type system. My take on it is WN is going to use this as a learning experience in a way. Since they have never had a multi-type system, or its been a really really long time since they went from a 727 to 737 fleet with some dual types possible, having some experience with a couple types in the fleet might be very useful to WN if they do decide to not go with the Next-Next-Generation 737. This may be due to WN going with the possible replacement to the 737, Airbus A320 NEO, C-Series or the other choice. My $.02.
    -Tad
    "Since they have never had a multi-type system"
    That statement is TOTALLY UNTRUE!!!
    the 737s that have been and currently are in WN's fleet are variants of each other and therefore make up a multi-fleet type system...in which they all require different training, different parts, different procedures. While they are based on the same FAMILY of aircraft they are of different design. Go take a gander at WN's training facility.....I'd wager to guess you just might find more then one type of 737 simulator...
    Think of it this way.... A Ford Mustang GT is a FAR different car then a Ford Mustang Saleen series...same family different model, different engine, different suspension, and a different tranny. Much like a 737-700 and 800 are different then a 500 and 300.
    The 717s will stay in place as they allow Airtran to serve half the markets AirTran currently serves. I'm not going to put up the link because based on reading this thread some folks REALLY need to do some research... There's a number of good studies that show the C series may very well be in WN's future as a replacement to the 717...oh those studies are not done by hack job college prof's but by real experts..
    Quote Originally Posted by JetBlueAirwaysFan View Post
    Does it really matter? Its just a word.
    Mar 2009
    DFW Area
    I do apologize for my previous post. I used the term multi-type, where in fact I should have been saying multiple airline families. While the 737 Classic's and NG's are quite similar in appearance and some operations/parts, they are also very different and thus require different parts/procedures based on variant. I didn't think of the whole picture as I was writing my response, but was remembering somthing specifically about the cockpit differences between the variants and pilot training.
    From the cockpit standpoint WN made it a requirement to Boeing that the cockpits of the -700's needed to be standardized to the cockpits of the -300/500's so that WN pilots could move to different types throughout the fleet without having to train differently. If you look at the cockpit of a WN -700, while it is glass it looks completely different than any other -700 cockpit out there. I remember one of the Boeing solutions incorporated is a plate over one of the features of the -700 cockpit so that WN pilots would not be able to utilize it (though the pilots did find a work around). Also if I remember correctly, the FAA even certified the WN cockpits differently from what I recall.
    Here is an example taken from Airliners.net:
    Southwest 737-500 cockpit:
    Southwest 737-700 cockpit:
    Transavia 737-700 cockpit:
    -Tad
    Aug 2005
    Southern Illinois
    Within the Southwest Airlines system, the 737 is considered one type, and one rating, 737. That is all a Pilot needs for SWA is a 737 type rating, which qualifies them to fly on 737-500, -300 and -700.
    The -700s are no longer in that configuration now, they were changed and modified back to PFD/ND which is Pilot Flight Display/Navigation Display, and when SWA did the RNP (Required Navigation Program).
    The different training and procedures not so much, there is SLIGHT difference, but once the -700 got changed different parts, yes depends on what part you're referring to on each of the 737 type.
    The 717 is going to stay for the time being and will be painted in the SWA colors. In time you will see 737-300, 737-500, 737-700, 737-800 and 717-200.
    Alex
