JP.net recently rejected a photo of mine:
where the plane was hitting/brushing by a tree on final approach.
- Bad Composition (bad framing / aircraft not centered)
- Obstructing Objects / Foreground Clutter
I know it looks similar to pictures where a tree is in the foreground, and the plane is way above and behind it (in which case a rejection would have been justified), so I reiterated that the plane was at the same height and in the path of the tree, and that it was actually touching the tree. In that appeal, they rejected it again, and stated "
perhaps standing somewhere else or shooting just a second later could help".
No s***, Sherlock! Of course I have other pics of this sequence, but this is the only one that shows the plane touching the tree (you know, which is so common on JP.net)! And yes, I should have stood somewhere else, knowing that this plane would hit the tree, and a few leaves would block the gear. Meanwhile, I saw a 2000-era film/slide scan that had just been accepted, that had color, contrast, and centering problems (horizontal stabilizer cut off at the tip and way low in frame) -- and was the dirtiest scan I've ever seen accepted (lint, white spots, film emulsion anomalies, etc.). And there were already 30 pics of that plane in the database. I almost lost it, but decided to just ignore it and not submit to JP.net anymore (or at least for the time being). Not worth my time and aggravation.
So to you, Mark, I say: perhaps you could have stood somewhere else, like 4 miles on the other side, or perhaps you could have used fill-flash.
