Page 10 of 38 FirstFirst ... 6789101112131420 ... LastLast
Results 136 to 150 of 559
Thread: Uploading to Anet/JP? Pre-Screen Here!
  1. #136
    Quote Originally Posted by NIKV69 View Post
    I never use poles or trees to level use the horizon. That show may get in with a little CCW. It's a pretty smashing shot.
    And maybe a tighter crop on the nose. I have gotten rejected on motive for including tiny bits of a wheel strut and the screeners have confirmed they rather see all the wheel or none of it but not in between. Just a thought...
  2. #137
    Mar 2010
    I never use poles or trees to level, use the horizon. That shot may get in with a little CCW. It's a pretty smashing shot.
    Thanks Nick! The light on it was pretty sweet at the time she returned!
  3. #138
    Any tips on what can be improved? I'm going to be submitting this pretty soon. The livery is not in the database yet so I'm hoping the screeners will go easy on me.
    Mat Czwakiel
  4. #139
    Matt..........to me the image looks soft, and maybe a tad more contrast, otherwise the overall composition looks good to me
  5. #140
    Yeah, I noticed that is the downside of the EF-S 55-250mm at certain zoom ranges. It might have been my panning technique as well, because some of the images I have captured within that zoom range are pretty sharp.
    Mat Czwakiel
  6. #141
    Senior Member RomNYC's Avatar
    Jan 2011
    Away from home
    Have a little doubt about this one and how centered it is. Unfortunately I can't do much in regards to raising the plane up a bit... What d'ya think?
  7. #142
    Rom, it would get a rejection on center I am afraid... I wouldn't bother uploading to either db. Nice angle though... only time I have seen off centered accepted is if there are other elements worth showing in the frame.
  8. #143
    Jun 2009
    KCLT
    My dad took the camera out to DEN and got a bunch with this angle... thoughts?
    Adam Sheinhaus
  9. #144
    Jan 2011
    Away from home
    Thanks Manny, I kinda figured. Oh well!
    This photo was easy to center, unfortunately I don't have enough room to move anything... For other photos, though, I'm having a hard time centering, depending on the AC's angle. Any tips you can give for perfect center?
  10. #145
    Senior Member wunaladreamin's Avatar
    Adam, I'm afraid it would get rejected. If you upload as a tail shot using the B6 registration, it will get shot down for not being centered. An upload as terminal will get booted for the B6 taking up much of the foreground. Not to mention it is a little underexposed.
    http://www.sopicturethis.net
  11. #146
    Senior Member steve1840's Avatar
    Dec 2010
    Nashville, TN
    Im thinking of uploading this to JP.net What do you guys think?
    Steve Furst
    View my work @
    Furst Edition Photography
    JetPhotos.net
  12. #147
    Steve looks ever so slightly low in the frame and is quite soft.
  13. #148
    Dec 2010
    Nashville, TN
    Thats weird Nik, I hadn't noticed that when I posted it. When I look at it outside of the browser and forum post, it looks sharp. But I see what you're saying, on here it is looking a little soft. Is it possible that something is happening to it going through tinypic.com to post it on here?
    Steve Furst
    View my work @
    JetPhotos.net
  14. #149
    Quote Originally Posted by steve1840 View Post
    You will have to check the host sometimes they do things to the pic when you upload but the pic I am seeing looks soft to me. Also parts of the wing look off to me. Almost like the winglet is out of focus.
  15. #150
    I tried to resolve your issue with the centering from your provided image and also the sharpening (there are over sharpened areas because you should not be sharpening a low res sharpened image in the first plane, let alone a small JPG LOL.)
    I had to crop a bit of the real horizontal stabilizer to get it centered.
    Also, keep in mind this forum will reduce your image to fit with an 800px wide frame regardless of original size. You must RIGHT-CLICK | VIEW IMAGE to see it in full size.
    Either way, Nick is right, double check the site you;re uploading to and make sure they DO NOT mess wit hthe original Image.
    Pbase, Smugmug, Flickr, as examples that do not mess up the original unless you tell them to.
