Akie,
Why did you upload at less than 1000? You just didn't know or was it an accident? It is also a bit soft indeed. Nothing you can't easily fix :-)
Akie,
http://www.airliners.net/procphotos/...281n652sw3.jpg
"Low contrast, narrow 1 pixel wide border all around image." My biggest question is I don't see the 1 pixel border. I've had a couple more rejected for border,and I can't figure out why. I'm using Element 10 for editing,and I haven't had a border issue until recently.
Doug
If you open up http://www.airliners.net/addphotos/r...281n652sw3.jpg against a dark background (like in Firefox), there is a faint/transparent 1px border around the image. Sometimes happens after you sharpen.
Wow, I have not heard of that happening before. That would be a hassle if you have to do another crop at the end of your workflow just to make sure it is not there. About the picture, what is going on with the nose of the plane? Looks like some skin work, it almost has a "zipper scar" on it. :frown:
Whenever I have that problem, when I resize down from the original, I make the photo 1px bigger on each side (so 1002x669 for a 1000x667 photo), then do the sharpening, and finally crop out the 1px edge by changing the canvas to -2px horizontal/vertical relative, making it 1000x667.
Oversharpened and Blurry
http://www.jetphotos.net/viewreject_b.php?id=4029880
Soft/undersharpened
http://www.jetphotos.net/viewreject_b.php?id=4029879
does anyone see how this is oversharpened?
http://www.jetphotos.net/viewreject_b.php?id=4055999
Contrast. Im not sure
http://www.jetphotos.net/viewreject_b.php?id=4055993
These were all rejected by jetphotos today.
http://www.jetphotos.net/img/3/5/4/8...1355097845.jpg
http://www.jetphotos.net/img/4/9/7/4...1355097479.jpg
http://www.jetphotos.net/img/3/3/4/3...1355097343.jpg
http://www.jetphotos.net/img/4/7/6/1...1355097167.jpg
http://www.jetphotos.net/img/3/7/0/9...1355096907.jpg
http://www.jetphotos.net/img/3/3/3/7...1355096733.jpg
http://www.jetphotos.net/img/4/0/1/4...1355096410.jpg
http://www.jetphotos.net/img/3/4/3/1...1355096134.jpg
Wasn't surprised most were not accepted. Only surprised about the Frontier and Airtran. The MD-90 Delta was only rejected because it was underexposed, so I may try again with that one.
