Originally Posted by
gonzalu
Jeremy,
Thank you for the original. Yes, I see a lot of Chromatic Aberrations... especially on the edges of the image :-( What lens? In any case, This will be a difficult image to get accepted. You absolutely need as sharp and motion-blur-free originals as possible. While you can get away with minor motion blur or even OOF shots, CA is a bitch to hide ... even when resizing. CA also has a huge impact on overall sharpness perception. And remember, sharpness is a perceptive beast as well as physical :-)
The image is also slightly overexposed (at least to my taste) but luckily there is enough data left in the whites with detail...
So I played a bit... workflow:
--Open image, crop and rotate. I used the columns on the building to get as close to horizontal as possible
--Check for dust. Clean up anything that may be considered dust
--Mask the plane. This is my personal taste. I work a bit harder on getting a good clean mask of the plane and then save it as a channel. Never know when you will need it again LOL.
--Levels. I will usually manually set my channel levels. I remove all non existing data from each channel from both the highlights and the shadows side of the histogram. This will also have a side effect of balancing the colors. If they were way off or way close, you can tweak it further with the center eye dropper on the RGB channel. On this image I also moved the midtones slider way down to decrease the brightness in the highlights without loosing detail. Look especially at the node of the plane and also the engine nacelles. You will see extra details there
--Resize to 1024, BiCubic
--Layer Copy
--Sharpen, USM, 200,0.2,0. Three times for this image which is overkill for the entire image...
--Mask the areas that need less sharpening from those areas that need it more. In your case, I masked the buildings and runways about 50% and then 75% of the titles... I left the nose and tail at 100% USM.
Let me know what you think... again, this is VERY SUBJECTIVE! There is no one way or perfect way.
Your original resized to 1024 for comparison
