Sorry, I rounded off. It actually weighs 8.35 lbs to the exact weight is 50601 lbs.
After some research, that excavator is a Liebher R9800, with a shovel capacity of about 42 cubic meters.
http://www.liebherr.com/me/en/produc...106220!11929-0
(earlier error corrected)
1 cubic meter = 1.308 cubic yards
(42 cu. m)(1.308) = 54.936 cu yds
(202 gal/cu yd)(54.936 cu yds) = 11,097.072 gal
(8.35 lbs/gal)(11,097.072) = 92,660.551
:D
Your math is wrong because you said 47x1.308, but you earlier quoted the Liebher as holding 42 cubic meters. Where'd the 47 come from?
103,000 lbs sounds a bit high though.
The numbers seem astronomical to me, but if it is indeed 42 cubic meters, I come up with 92,075 lbs of water.
An average household pool that's 24x16x4 holds about 11,500 gallons of water, and size-wise, that scoop looks about right. So maybe the numbers work.
Keep in mind, the Evergreen Supertanker can carry 20,000 gallons, at a liquid paylod of 167,000 lbs.
Oh snap, Phil has got his geek-on.
.....when I wrote it out on scratch paper, my two looked like a seven....grr...you're right...
what have i done? speaking of geek, who know how to convert fuel from pounds to gallons and vice versa, without calculators?
always cross out sevens and zeros...Quote:
Originally Posted by GrummanFan
Don't let Phil fool you, he was a loadmaster & is a Dispatcher, he speaks geek, fluently :wink:Quote:
Originally Posted by mirrodie
Originally Posted by cancidas
LOL! Some of us used to work for FBO's that were too cheap to give us calculators :mrgreen:
