The IS gives you 2 extra stops on the shutter when hand-holding. So, using the hand-holding rule of 1/focal length seconds; the slowest hand-held speed that you should use with a 250mm lens is 1/250. With IS, you can hand-hold that 250mm lens 2 stops faster, which would be 1/60.
