Just Re-Visited T4 at JFK
I visited JFKs' T4 for the first time since Delta moved-in. I was not pleased with the mobs of travelers on the Ground Level as well as the broken elevators on both sides of the Terminal. Portions that used to be open to the public now have security gates to stop non-ticketed visitors. Hopefully, when new construction gets completed, the crowds will dissipate. I wanted to check-out the new Delta lounges shown in newspaper ads but there was no access of course. I moved on to T5, the Jet Blue Terminal is extremely modern with bright lighting, modern counters, quick-moving elevators, pleasant staff and clear signage; it was very appealing. Stations to charge electronics were in abundance. The Wi-Fi available was not free at terminals I visited and you might need a password. I found no auto-sign in. The AirTrain had great service on both tracks. I thought I might catch a glimpse of that solar-powered aircraft. I don't even know if it's still at JFK but since 1 wing was damaged, I figured it might be around; never spotted it.
